mercury problems help!!
oldgradywhite
I have a 1985 90hp mercury. I did a compression check the other day and it was as fallows 1# 120 2#90 3#120 4#110 5#100 6#105 I also here a small amount of noise from the crank in one of the cylender but it is not bad. I have decarbs this motor before the compression check too. I was told this motor was a pos and wouldn't be worth fixing. what should i do
Re: mercury problems help!!
Ayuh,........ It'll only get Worse,.... Til you Fix it........
I only see 2 options,.........
Either tear it down,+ Fix it,........
Or,........
Junk It........
There is a third option -- run it until she blows.
jcsercsa
Yea could run it till it dies , then what 1500 on a used one or 5000 or 8000 on a new one ?? and what does it cost to get one rebuilt???
Robj
Or see if you can find the same motor with a wrecked leg, and then put the powerhead onto your engine. They should be fairly cheap.
Have a great day,
Rob.
