The issue with this 470 Rib is that the hull is nearly 20 years old, develops a tremendous front hull drag due to its odd shape when on plane at speed. Would say it's worse than a dog when running. Splashes too much water at side of front hull which slows the combo real bad.
Don't understand why you guys are so surprised that a 11 pitch won't perform right, it's a 4 stroke motor which is slow on hole shot compared to same 2 strokes ones, it's the nature of each beast. Worse if not propped right.
The number stamped on prop body indicates being an 11 pitch, right ? The blades are the Mickey Mouse type, round wide ears which intend to keep using but with a lower pitch say a niner.
Some weeks ago made a 20 Km wot race down current at open sea. Both 470 and 450 Ribs runs standard delivered props and both has the same old hull type. My 450 Rib is a much lighter champ, has a state of the art deep V straight hull in comparison. At flag down my Sib took the lead for some kilometers as jumps on plane real fast, soon after both 60's took the lead till the finish line.
If you check closely the difference in distance between both 60's and my 18 is not that big deal, all motors were running full hammer down since flag down. Both 60's runs good around 5 K with 4 up while my motor runs at full 5850 wot revs factory stated with 2 up. A correct prop maximization is the way to go if wanting to get the max HP out of any motor...
Happy Boating
