JimS123
- Jul 27, 2007
- 8,316
Nope, in this precise example if the AV plate rides above the water level which is ridiculous or under what's the use of the doel fin, that I know a doel fin must ride fully submerged and parallel to the water level to work right, unless you want to use it as a step lader when climbing on board from behind...
Happy Boating
If a Doel Fin is submerged on plane it will cause drag and reduce your speed. On some hulls it could also make the boat squirrely. It needs to be submerged at idle to provide the needed lift to lower planing speed and reduce bow rise. But then at plane it needs to be just above and skimming the water level. With those 2 criteria met, you'll have an optimum setup.
Now, change props to get WOT right at max spec rpm and you'll have the best of both worlds.
Regardless, based on the picture provided in one of the early posts, that ain't no Doel Fin. I can't read the label, but my guess is that the "fin" is an SE Sport, which is not noted for performance.
Lose the fin, raise the motor so the AV plate is nearer to the boat bottom, dial in the rpm and then put on a real Doel Fin.
