Re: Mercury Sportjet 90 bogs past 4K
I appreciate everyone's replies. I'm making progress. I pulled the powerhead, thoroughly cleaned and replaced the head gasket with a new one (no RTV - learned the hard way). While I had the powerhead out, I also switched the complete ignition system back the newer one with the red stator, new switchbox, regulator, coils, wires, and rev limiter.
The new head gasket made a dramatic improvement in the engine's power, ease of starting, idle, etc. Also, no fuel/oil/water mix is leaking around the bottom powerhead to jet bolts. No fuel smell in the engine compartment - a first in a while.
So now the bog would be better described as a "surge".
I immediately noticed an increase in hole shot power, ease of keeping the boat on plane --- for a few seconds ---- it runs great to 5000, then it's like someone is standing on the fuel source and QUICKLY slows to 4200,QUICKLY jumps to 4600, etc all without me touching the throttle. Once it finds it's happy place if I pull back on the throttle (in the usual spot for about 4000) it will run 4300 and stay on plane - surging only 200rpm +/-. Plenty of power and it runs smooth LIKE NEVER BEFORE THIS YEAR -
but I can't get it to hold this RPM at WOT which is where I need it.
- I disconnected the black/yellow wire on the rev limiter just to be sure - no change.
I read something last night to pull the plugs immediately after a high speed shutdown and see what stories they have to tell.
- Top #1 - Wet - light fuel/oil mix - no carbon deposits
- Middle #2 - light carbon deposits - dry
- Bottom #3 - light carbon deposits - dry
I swapped spark plugs and leads - no change - still #1 was the wet cylinder. The coils tested fine last week -
but coil #1 could be suspect or is it fuel?
Could my float be sticking in #1? I just had them apart this past weekend, cleaned, checked and reassembled. I did not pull the welch plugs (but did reseal them) so I could not get to the nozzle. I sprayed carb cleaner in everything and blew out with clean compressed air.
The new floats that came with the Merc rebuild kit were not adjustable. Could this be a problem?
Should I try the old float? It seemed to be in good shape - just wanted to go for reliability on the rebuild.
Other thoughts. I can go back to the test tank again and be 1000% sure there isn't a fuel delivery problem - but fuel doesn't seem to be the issue - there is fuel to all 3 carbs and even when I pulled the head all 3 cylinders had fuel/oil in the bottom of them.
I'm just figuring there is too much fuel to carb #1 which is causing the smoke after the bog at the ramp when going under full load. (can't see it on the lake at speed).
If there is too much fuel dumping would it create a wet cylinder? I'm guessing a loss of spark would also?
Again, everyone's thoughts are appreciated - I feel like I'm fixed a symptom with multiple problems or vv?
George
