Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
Chris1956
All, I am considering the title, three props, all in 3 blade and 21" pitch for my speedboat. My speedboat is an old Avenger, 16 footer, 670# w/o motor. I have a 135HP Merc V6 on it. I have used 21P props for years, and they work pretty good. Max speed is 55 - 65MPH, without anything special. I think I need bow lift as the boat rides pretty flat.
The approx. price range for each prop:
TP Mach 3 <$400
Merc Tempest $750+
Mich Wheel Apollo $450
Opinions
jlh3rd
Ensign
I prop for the higher end of the manufacturer's recommended max rpm @WOT for the longevity of my engine.
Everything else becomes what I'm left with.
Pmt133
I wouldn't commit to something I couldn't at least test but... all three are pretty solid choices. The tempest and Apollo are very similar if memory serves. The turning point is more like a inbetween of the mirage and enertia. The mach 3 (both the regular and OS) have been reported to cause a lot of porpoising on some hulls. My 19 didn't like any turning point I ran. Not saying its a bad prop... just didn't work with my hull. Same as the enertia. That prop is magic on 95% of hulls... mine slowed down everywhere with it and handled... weird.
airshot
If my memory serves me correctly, the rake is what controls bow lift, but you need someone with more prop expertise than I have.
Texasmark
Considered Ballistic props? Their SS blades have a lot of Rake and squared off, cupped tips on the blades. Lot of design there to get the bow up when you are after the MPHs. My last boat was a Crestliner 17 1/2' Fish Hawk dual console with a 2002 2 stroke 115 Merc. Prop was a 22P Ballistic. It wasn't hard to hit 50 even with the rev limiter which was factory set to 5250. Don't know the upper limit if the RPMs weren't limited. The boat didn't have a pad but it had reverse chines with a fair dead rise at the transom both helping to get the hull up and out of the water.....without having the pad.
Chris1956
Gee, I found a place on the net that said Michigan Wheel no longer makes OB and sterndrive props. Yikes - is that true?
Texasmark
Well if they quit doing that, what are they making...just props for larger vessels or going out of business?
jimmbo
I highly recommend the Mercury Enertia. Been running one for over 20 yrs, prior to it I was running an OMC RAKER. The Enertia, lifts the entire Hull vertically, and still gives good Bow Lift.
The Outdrive is not producing a Roostertail, so I am not over trimming
