Mercury Tempest, Turning Point Mach 3 or Michigan Wheel Apollo?
All, I am considering the title, three props, all in 3 blade and 21" pitch for my speedboat. My speedboat is an old Avenger, 16 footer, 670# w/o motor. I have a 135HP Merc V6 on it. I have used 21P props for years, and they work pretty good. Max speed is 55 - 65MPH, without anything special. I think I need bow lift as the boat rides pretty flat.
The approx. price range for each prop:
TP Mach 3 <$400
Merc Tempest $750+
Mich Wheel Apollo $450
Opinions
jlh3rd
Ensign
I prop for the higher end of the manufacturer's recommended max rpm @WOT for the longevity of my engine.
Everything else becomes what I'm left with.
Pmt133
I wouldn't commit to something I couldn't at least test but... all three are pretty solid choices. The tempest and Apollo are very similar if memory serves. The turning point is more like a inbetween of the mirage and enertia. The mach 3 (both the regular and OS) have been reported to cause a lot of porpoising on some hulls. My 19 didn't like any turning point I ran. Not saying its a bad prop... just didn't work with my hull. Same as the enertia. That prop is magic on 95% of hulls... mine slowed down everywhere with it and handled... weird.
airshot
If my memory serves me correctly, the rake is what controls bow lift, but you need someone with more prop expertise than I have.
Texasmark
Considered Ballistic props? Their SS blades have a lot of Rake and squared off, cupped tips on the blades. Lot of design there to get the bow up when you are after the MPHs. My last boat was a Crestliner 17 1/2' Fish Hawk dual console with a 2002 2 stroke 115 Merc. Prop was a 22P Ballistic. It wasn't hard to hit 50 even with the rev limiter which was factory set to 5250. Don't know the upper limit if the RPMs weren't limited. The boat didn't have a pad but it had reverse chines with a fair dead rise at the transom both helping to get the hull up and out of the water.....without having the pad.
Gee, I found a place on the net that said Michigan Wheel no longer makes OB and sterndrive props. Yikes - is that true?
Texasmark
Well if they quit doing that, what are they making...just props for larger vessels or going out of business?
jimmbo
I highly recommend the Mercury Enertia. Been running one for over 20 yrs, prior to it I was running an OMC RAKER. The Enertia, lifts the entire Hull vertically, and still gives good Bow Lift.
The Outdrive is not producing a Roostertail, so I am not over trimming
Texasmark
Even if you were (over trimming) that's one helluva picture. What's your MPH....65? I don't see a "pad" but the lifting strakes down the hull surely help you to get where you are......the fine spray mist helps to support your speed.....moving right along....noticing your caps on backwards so it won't blow off even with the windshield deflecting a lot of what's hitting you in the face.
jimmbo
That Hull doesn't have a Pad. I was taking the Picture, my Cousin was in the Boat
jimmbo
5.7. It wasn't offered with the 5.7 but rather with a 5.0 with EFI(horsepower was the same as a 5.7 with a 2bbl Carb), but still, it came out of the Factory with the 5.7(I think there were 6 or 7 of them, used at a Dealer Convention/Show). Wouldn't want anything smaller in it. It has enough torque to almost have the Holeshot of a 2 Stroke outboard. I did run into someone with the FI 5.0, and while the top speed was close, I was several Boat lengths ahead. That was with the 500cfm Holley 2bbl. I have put a Holley 650 Spreadbore on it(no Intake was needed, as Volvo used nice Intake very similar to the Intake on the 70-71 LT-1s, and used an Adapter to mount the 2bbl) and gained several hundred Rpm, and another 7mph, but a Higher Pitch Prop was needed to bring the Rpms back to the recommend Range, and that hurt low end grunt, even with the Small Primaries of the Spreadbore.
Texasmark
Since you mentioned the prop, were the two pictures....the upper picture of your boat on the water vs the lower right picture of that black prop taken with the prop shown being used in the upper picture?
jimmbo
No, I was running an OMC RAKER in the Pics of Boat moving. The Black Prop was the AL Prop that came with the Boat. I still have it as a Spare
Here are my 3 SS Props. In the Center is the Enertia, the others are RAKERs
jimmbo
The RAKER is a Good Prop, the Enteria is Better.
RAKER was introduced in 1985 and the Enertia in 2005.
Props haven't changed much since, though was some goofy looking thing a few year ago, that a couple of people on this Board were tripping over their Tongues about, but it has NEVER been released nor review by a Reputable Source. Plus it cost over $5000, and was not Repairable
