MFG rebuild getting started pics
craigweaver
Re: MFG rebuild getting started pics
SP, holy crap that looks like it was always that way! You are makin this look awesome man! That splash and new seats are sweet!
keep on keepin on bro!
sphelps
Thank's CW I appreciate the encouragement! I gotta go back and see how you taped off your green stripe on your thread. Been thinking about stripes..
Well today I put another coat on everything it didn't go quite as well as the first . Little problem with the hvlp but Wood's helping me out with it . We'll get it worked out.
So I started mixing the color paint I still need to go darker but it's getting close. I'll work on it some tomorrow..
I started with this..
Got tired and got to get ready to go back to work tomorrow. This is what I have now..
Have a good start to the week everyone !
sphelps
Put the 3rd coat of primer on the top cap this evening . Thanks to WOG for steering me straight on the hvlp.:cool: After completely disassembling ,cleaning , and putting back together it worked fine with no problems. Thanks Wood !! I do need to pic up some more of the disposable moisture filters it sure seems with the heat and humidity the compressor generates more moisture !
Gunna try and get my paint formula figured out tomorrow but I have to cut the lawn first.:mad:
See ya !:)
Trooper82
Glad you got it working....I see more sanding in your future :)
Have a good week SP...
Colorado_Boater
Good work SP,
I can't believe how well that painting came out, I'm coming to you when I get that that stage with the bayliner.
sphelps
Trooper,
Glad it's just light sanding.:rolleyes:
CB,
Thanks and come on down it just might fit in my garage once you cut the top off .LOL
Woodonglass
I think you're gettin close on the paint color. Just keep track of the measurements and you'll get there. Glad the gun started working for you. I tear mine down 100% totally after every job. I know it's prolly over kill but that way I KNOW it's just like it came from the factory the next time I'm ready to shoot. I replace the H20 filter every time I shoot as well. I use the $3.00 cheap ones from HF and they work well for " 1 Job" shoots. I drain the compressor everytime too! Doing all that I STILL had a water problem when I shot the BF and I almost had a Coniption Fit when I saw the water droplets on my Bow!!!!!! Turned out it was a bad hose fitting and not a filter issue or a gun issue though.
Pmccraney
S.P. - The stern splashwell/seating combo turned out absolutely incredible... It looks like it was popped out of mold.... Just awesome...
sphelps
Pmc,
Thanks I just hope the paint and seats turn out just as well..
Wood ,
Been adding a level TSP at a time and keeping track . It sure is taking a while. Here is what I got so far.
I'm thinking it needs a good bit more blue ..
Almost like I need another color added..
Woodonglass
Yep, you are WAY off on the green. Try this use a 1/4 cup of white and then add a tablespoon of blue NO GREEN. Add more blue till you get close to the shade of baby blue like mine and then add 1/2 teaspoons of green to get a bit of aquamarine in it.
jbcurt00
WOG's got ya covered...
sphelps
I'll give that a shot tomorrow . I had started with a cup of white . I think that was way to much for as dark as the color is.
sphelps
Here is my latest attempt . It's getting closer I can't tell If it needs more blue or green.
bottom color is the latest.
It dry's darker I dried it some with my heat gun.
sphelps
My son suggested that I paint the inside lap strake hull a few shades lighter but the same color of the top cap. That would give some contrast to it. The allum rail had white and black textured tape on it but I think I willpaint it instead of the tape.
Trooper82
I won't be any help with the colors SP, but looks like you are getting real close.
sphelps
OK here is another stab at it..
Very very close !
Woodonglass
If you ask me, I'd say #5 is Spot On. #6 has some glare on it so hard to tell. What's the final formula???
sphelps
1/4 cup or 4 tbs - white
4-1/2 tbs - blue
1-3/4 tbs - green ( 11 ---- 1/2 tsp)
It's hard to get a shot without the glare I will take it out in the sun and check it out tomorrow.
Decker83
Looks like your getting real close. I agree with WOG. #5
