MFG rebuild getting started pics
Woodonglass
Re: MFG rebuild getting started pics
Seats are gunna look great in the boat. Guess surging the pump didn't work. You might try disconnecting the fitting from the front of the pump and running the garden hose down as far as you can and then seal the pipe with a towel around the hose and see if if will reverse blow out the obstruction. If you have a lot of 90? joints then prolly not much you can do. Do you know a Nurse or a Dr. that you can borrow a Stethascope from. You can sometime LISTEN and hear gurgling at the point of an obstruction.
sphelps
I could not get the fishtape to feed from the skimmer . I,ll send you a pm and explain what I got going . Don,t know anyone with a stethoscope..
Decker83
The seats look like they came from the factory.
They really look great. I'm with JB, the white pipping does a great job in setting off the colors.
Can't wait to see them in the boat.
Hope you get the swiming pool problem fixed quickly.
tallcanadian
Ditto on the seats. They look awesome. Great job, they will look real nice in the boat.
Pmccraney
Seats really do look great... Super...
sphelps
Yep the white piping looks good and it will match the white vinyl edge molding that will run along the bottom edge of the top cap inside the cockpit area .
And if I can,t fix my pool I guess these guys could use a bigger tank !:rolleyes:
TC, saginaw, and Pmc -/" Mayor of Foamville " :D
Thanks gentlemen !
jbcurt00
Oscars :) I moved just as mine outgrew their tank. Went to a co-worker w/ an empty 75gal :cool: Had 'em for years, from 1" to almost 9.5".
Really interesting fish. They'd ignore my roommate, but go nuts popping the surface of the water when I walked in the room. He who brings the food is king I guess;)
sphelps
Yep , my son forgot to feed them for a couple of days and when my wife tried to feed them they would just lay on the bottom playing dead ..
When she walked out of the room they came alive and ate the food . She walked back in and they would lay on the bottom again .. LOL !
sphelps
Not to much going on this weekend . Had to work all day yesterday . But I did manage to get the air hole grommets installed on the seat backs . Don,t let those little things fool ya . They were kinda a real pita ! Maybe it was my elcheapo grommet pliers ...
Anyway on a much cooler note my most wonderful, thrifty , thoughtful ,and beautiful wife scored something I needed/ wanted for the boat on fleebay ! Nothing major but none the less pretty cool ..:cool: I,ll post some pics when it comes in..
Gotta feed the hamster need to start building seat bases. I also need to make a to do list so I can focus on getting done ..:facepalm:
Trooper82
Looking nice!...did you need to put in a hole first?
sphelps
Had to use a grommet to make the hole then clamp in a new one ..
sphelps
I got the hinge pieces all cut out for the seats . Still need to clean them up then figure out the nuts and bolts to put them together with ..
I was thinking on painting them but I don,t know how well the paint would hold up ..
My original cleats are painted aluminum . I guess I can prepare them the same the same way as the gunnel trim I already painted . My tractor paint should hold up for a while I guess unless anyone has a better alternative. Maybe something from a rattle can ?
sphelps
Not sure but it looks like it does not come in white ..
craigweaver
holy carp!!! :eek: Those seats are AWESOME!!!! way to go. I love the inset color and the white piping.
sphelps
Thanks CW it,s good to hear from ya ! Now it,s your turn to fire up that pretty pink Morse ! Sure wish I had better machine than the one I used . Maybe next time . Wait, did I just say next time ?:eek:
sphelps
The Admirals ebay score arrived in the mail today ..:) New old stock step pads . There are 4 of them . Kind of small so debating on whether to dbl em up or not . I will line them up on the white stripe on the jump seats..
I think I like the single better..:cool:
