MFG rebuild getting started pics
jbcurt00
Re: MFG rebuild getting started pics
You have now pretty much exhausted what little knowledge I had, sorry...
If you use gel w/ wax, don't you have to sand between coats? But if you have to get back on it, I guess you need it to be cured to be on it while rolling on the 2nd coat.
Tape & plan seem to make sense.
Time to turn on the YD bat-signal for gelcoat help.... Anybody heard from oops lately?
sphelps
Jbc ,you always give great advice . Way more than you may think . And every now and then a post that will have me raoflmao ! That,s always welcome !
Ok now another ? Will poly resin adhere well to pvc pipe ?
Woodonglass
NOPE! Heck Epoxy won't adhere to it. What are you wanting to do??
sphelps
Well way back in my thread I talked about this rib that ran along the raised section of the bow deck . This creates a very undesirable duck pond every time I wash the inside out . You suggested gluing in a few drain tubes which sounds like a good idea . So I am at the stage where I need to finish the deck and would like to install them before the gel . I also need to install a vent tube going under the deck like it was from the factory .
Been thinking how I wanted to treat the area under the bow deck but I have not come up with a plan yet . I kinda like what Jon Sob did with his Carefree ..:)
sphelps
Here is an old pic
Maybe 1/2 " ..
sphelps
Had to break out the boat snuggie today been pretty chilly down here ..
Had just enough resin on hand to pb in the seat pads and put one layer of csm down ..
Worked Saturday so we could have Monday off so me and the admiral are getting up early picking up some more resin and going out for breakfast !:)
Woodonglass
I remember now!! I'd use 1" cut in half. Drill a 1 1/4" hole an use Hairy PB to set em in place. IF they come out, no problem cuz the PB will still be in place. HECK you could put vaseline on the pvc and then knock it out when the PB cures.
sphelps
Ahaa I new you would come up with something ! The only setback ,well not really a setback , is when I drill the hole the bottom will be open so I assume grind gel back and kinda lay a layer or two of glass on the bottom then install the greased pipe and pb . This rib looks structural so I need to make it as strong as possible ..
Woodonglass
You got it. Dig out the bottom a bit and glass it smooth. With the Gelcoat finish It'll last till your Grandkids R yer age!!!!
Happy New Year My Friend!!!!
sphelps
Thanks Wood, Trooper !! Hope everyone has a wonderful 2013 !!
Just messing around on the last day of this year I decided I needed to do a sound check .
Click the pic !
Trying to figure out where mount the trumpet ..And as you can see the front bracket is not the same height as the main bracket . Just seems weird !
Woodonglass
I'd mount it as far on the Starboard side as you can get it and still line the front of the trumpet up even with the front of the drop off.
saginawbayboater
Happy New Year to you to Sp!!! Your horn just freaked out my family they are playing cards at the kitchen table and I blew the horn at em
! LOLOL
sphelps
Woody I agree that's prolly the best spot for it ..
Sbb , LOL! I just scared the carp out of my dog that was sleeping next to me in the living room . It is pretty loud !
Not much boat stuff today I needed to take care of much needed yard work for the admiral ..But I did manage to cut the holes for my bow deck duck pond drains ..
Yep and I did cut the pipe to short and dropped it under the deck . :facepalm: :lol:
I stuffed the lens in the hole and took a pic . I,m surprised the pic turned out .
This is the first glimpse of anything under the deck that I have seen . I guess I,ll try some bubble gum on a stick to retrieve the piece of pipe . LOL ! :rolleyes:
Woodonglass
5 min epoxy, thicken with talc, small stick with blob of epoxy on it, camera to make sure you're on it. wait 5 mins and remove. Voila'
sphelps
Thank you Lord ! Finally got my new well installed !!
No more bringing in jugs of water from work ! :whoo:
sphelps
New well pumping beautiful , clean , clear water ! :)
OK back to the boat .. Layed up some glass to make these little backer sheets .
Then pb,ed in place ..
Next temp install the the sleeves and pb around ..
