MFG Seacruiser
adoseth
Re: MFG Seacruiser
The kit came with some spacers that you put between the front and rear skin so that the transom comes out thick enough,other that that no braces,the shape pretty much stayed good enough however when i did the transom 11 years ago after removing the old transom the rear skin had lost about 5 degree of its angle same was the case this time because i never tried to bend it back , so i found motor mount wedges to place between the engine and transom to get the angle back that it used to have, the wedges were 5 degree.
It took almost 2 whole 5 gallon kits, i had as bit of leftover, also the upper left and right side of the transom where it curl's up still need to be filled but from what i understand that particular area doesnt actually provide support for the transom it is simply cosmetic so i will fill it with glass none the less and smooth it out the way it was when newtransom small.jpg this picture is before the pour, i was still removing the old transom wood
You shouldnt have to worry about it bulging out as long as the front and rear skin are thick enough, it was actually tough getting it to spread open far enough to get the spacers in
sphelps
Re: MFG Seacruiser
Glad it turned out well. I can,t wait to get mine poured . I maybe going a little overboard with my prep work .
adoseth
Re: MFG Seacruiser
I wanna see some prep work !!! LoL, got any pic's?
SteveMFG_Oxford
Re: MFG Seacruiser
I sure envy your Florida weather! Tough to get much boat work done here in PA when the temps are below freezing. If I had your weather I'd be almost finished by now!
Keep up the great work. It's so nice to see these old classic boats when restored.
Love to see some photos of the interior layout and helm area.
adoseth
Re: MFG Seacruiser
I'll grab some pics of the helm and interior tomorrow, helm is currently under construction, replacing wood behind the dash/ steering wheel and re wiring dash and replacing switches/installing guages
adoseth
Re: MFG Seacruiser
Update: Steering installed
Shift/Throttle cables installed
Electrical and Main harness installed
Splash well reinstalled
Engine:
Carbs rebuilt,new fuel pump,fuel lines
Ignition coils and plugs replaced
Water pump installed(waiting on thermostat kit to come in)
Still more to do but for now i am taking a couple nights off !!!
sphelps
Re: MFG Seacruiser
Man you are gitten it ! Your acting like you wanta go fishin or something!
Question, How many gal of seacast did it take for your transom , How bad was shipping costs?
I,m still debating nida bond vs seacast. It,s been ruff getting nida bond ordered. It,s phone tag city!
adoseth
Re: MFG Seacruiser
Sp, it took almost 10 gallons, i ordered 2 5 gal kits and i cant remember shipping cost been about 2 years since i ordered it. But yea i got boat fever so im taking advantage of my motivation !!!
I'll post pics when they get this website fixed
Jon Sob
Master Chief Petty Officer
Re: MFG Seacruiser
Pssssst ..... any updates over here? I know your not on hold because of the snow like I am ..... lol.
adoseth
Re: MFG Seacruiser
Hey Jon!!, so far since my last update i have finished the floor and 1 side storage shelf/ski rack, the trailer is all done as well, still have to put in seats,carpet,to make operable ,then i am going to take her out and see if i have any issues, if all is ok , then i will remove ugly bottom paint,and try and buff up the exterior a bit more, some areas are so bad that the gelcoat has worn thru to fiberglass so i may end up painting the blue areas, i was trying to post pictures last night of my progress but cant seem to get the pic's to upload, i will try again tonight
Jon Sob
Re: MFG Seacruiser
Great .... I would love to see some pics. I guess iboats is still a little messed up when it comes to posting pics. I opened a photobucket account ( it's free ) to post pics .... I guess for the time being that is the only way to post them.
http://photobucket.com/
Jon Sob
Re: MFG Seacruiser
Once the pic is uploaded when you hover your cursor over it a window will appear with all the various links. Click the bottom one, the IMG TAG. It will say "Copied" then just go to iBoats and paste it in where you want it to appear. Also set the size to 640x480.
sphelps
Re: MFG Seacruiser
Man you got a nice big garage! I love the boat, nice job on the paint inside!
Jon Sob
Re: MFG Seacruiser
sp is right what a work area plenty of room ..... Looks good. I like that wheel is that factory?
adoseth
Re: MFG Seacruiser
Thanks on the compliments , no the steering wheel is aftermarket,that the steering cable,shift/throttle lever and cables assembly were bought used,as with the motor , off of ebay or craigslist, i still have a lot of buffing to do, or possibly repainting, the inside walls are painted and the floor was gelcoated, im going to cover it up with carpet
Jon Sob
Re: MFG Seacruiser
Do you have emblems to replace the broken ones? I bought a pair from mark42 he makes them out of poly resin.
adoseth
Re: MFG Seacruiser
i have contacted him 3 times about those emblems, still no responce , but i need to get 2 of them
