hi I'm new here but your forums have been really helpful. I have a 1998 90 hp Force 3 cylinder 2 stroke. Went out on lake first time this summer and ran great. Had a buyer and went next day let him run the boat and wouldn't idol and started misfiring badly. Did manage to get it running WOT but about 5200 rpm. When we would slow down it would start acting up again. I was able to keep idol but I would have to tap the choke to do so. Cleaned carbs, new filter and new gas helped the idol but still misfiring at idol and anytime I tried to hold at steady rpm's. will rev in neutral just fine. Found that the #2 pack was not firing and causing the motor to sputter and spit till it dies. (Pardon my ignorance but is that called detonation when the fuel in the cylinder isn't able fire?) The tachometer is reading just fine. First thought coil pack but if I switch connectors from other coil pack the #2 fires just fine. This engine has a voltage regulator on it so not sure it that would cause a firing issue. just to be safe I bypassed the regulator and disconnected the yellow wires from the stator. If the problem moves when I switch connectors on the coil packs does that mean its a stator or trigger problem? I don't have a dva box just a regular multimeter. Any help would be appreciated. Guy still wants to buy boat but not for much longer if I can't figure this out. Thnx
