mixed gas turning dark yellow
atk82
i ran boat yesterday gas looked fine in my filter now today it turned a dark yellow and i just filled it up with fresh gas and oil i mix my gas 50:1 any ideas of what its from
atk82
Re: mixed gas turning dark yellow
I unhooked lines at filter squirted gas out until good gas came out reconnected lines drained carb bowls pumped bulb redrained bowls until I had only good gas draining out it's kinda weird the gas in all the lines r dark yellow but gas in tank is fine I would think if there's something in the tank all the gas would be yellow
A couple of guesses for you. Water in the gas? Maybe the ethenol is disolving some of the fuel line innards?
sschefer
It's normal. Go get some gas straight out of the pump, pour it into a container and let it sit overnight. It'll turn dark yellow. You're running oxigentated (sp) fuel.
atk82
Thanks for all the help I got a different tank to make sure it wasn't anything to do with my original tank n also got a new line n bulb from tank to motor to check it also but just put that on tonite finally got time what is oxigentated fuel
Brewman61
Ensign
Oxygenated fuel has a substance added to the base gasoline to boost it's oxygen content and burn more completely. Typically this is by adding 10% ethyl alcohol to the gas, also referred to as E10. Being Minnesota is in the corn belt, we've had 10% ethanol gas for a long time.
