Mmmm, Fresh transom...
CCrew
Nice to at least be to the point where I'm putting things together instead of ripping them apart :) Have 1 3/4" of plywood laminated together sitting in the garage curing.. Geez what a mess when the layers were screwed together! I'll be interested to see if it warps when it cures. <br /><br />Easiest to do the O/D cutout before or after it's installed into the boat? Thanks!<br /><br />-Roger
Re: Mmmm, Fresh transom...
Did you Alternate the orientations of the plywood..???<br />If you Did, It Won't Warp.......<br /><br />Cut out the hole After installation.... <br />Use the Hole in the boat as a template........
CCrew
"Did you Alternate the orientations of the plywood..???"<br /><br />Yes sir, sure did. epoxied the daylights out of the layers, with epoxy resin and 1 1/2oz epoxy mat between each one. Stainless screws in each layer on a 6" grid. Three pieces of ply, one 3/4" and two 1/2", all oriented 90 degrees to each other. <br /><br />Factory was the same dimension ply, no resin or mat, stapled together. Bilgeliner, what can I say?<br /><br />-Roger
msmorto
I Just did mine, but I cut the hole first<br />so that I can completly encapsulate the transom, I routed out the mounting hole and fill them with peanut butter, before installing on the boat, so I know that NO WATER is going to penetrate that transom :cool:
