Boomyal
- Aug 16, 2003
- 12,072
Re: model 888 overheats@ high r.p.m.
What thermostat do you have in it? 160 or 180 Deg? Remove the radiator cap from your heat exchanger/radiator before you start it. Keep an eye on the temperature guage. When the guage shows that you are near your thermostat opening, watch the coolant movement in the heat exhanger. When the thermostat opens up, you should see a rapid movement of coolant by the filler neck. If you don't, you've got either a water pump problem or a thermostat problem. Keep the cap off, watching as long as you can before the coolant expands, wanting to overflow the filler neck. <br /><br />If you do not know the t-stat temp, get a thermometer and stick it in the coolant. When the t-stat opens, causing the rapid coolant movement, that is your t-stat spec. You can use that to verify the guage on your boat as well.<br /><br />This is a diagnostic luxury that one does not have with raw water cooling.
