bob johnson
- Feb 25, 2009
- 4,306
so I cant help but think I don't want metal to metal contact with my gas tank and the ribs.. seems like if it isn't super solid, it will rub and might produce a hole.
what is it that you guys are using to cushion the tank from the ribs...if any
and do most of you leave an access opening for the tank, or at least the one end with the sender .
I will have to figure out everything that needs to go under the floor before I start to cut and fit my floor....
it is taboo to run electricals under the floor? or are they all run along the gunnels ???
BOB
BOB
