motor is here but but no fuel will not start.
Re: ordering motor in morning have you ever heard of
You are correct sir. They will bolt up. But they also have differing diaphragm materials and operating pressures, as well as longer/shorter levers. Like I said, wasn't trying to argue with ya'. :) A universal like the Holley can be made/modified to work with most any of them.
Ayuh,... 'n Badbowtie only needs 1 for his Mercruiser...
Just like the 1 he Broke....
badbowtie
Well I called teleflex which makes the pump and they said the same thing as you bond-o the ports are the only thing different. So I will have another pump here tomorrow.
badbowtie
Well I got another pump yesterday and got it on and pulled it out and it started right up. I have a clunk noise coming from the rear of the motor on the starboard side. It is not consistent and it only does it if I have the idle under 850 I can I dle at 850-900 and it will never make the noise I can bump the throttle up to 1500-2000 and it does not come back and sounds great. I have no Idea what it could be and it started to drizzle again so I shut it of and backed it back in the garage.
Ayuh,... If the idle is above 650/ 700 rpms, in gear, in the water, you'll destroy the drive in no time...
badbowtie
I figured I can't idle higher than about 650-700 but I am going to try to figure out what the problem is before I ever launch the boat. I just have no idea what that sound is never heard nothing like it.
badbowtie
I pulled the boat out again and started it again, I think the noise that I am hearing is the shutters in the y pipe, but I tried to set the timing I have the delco est distributor set up, and when I install the 4 pin plug that has the looped wire and connect 12 volts to the other wire, and set it to 8 degrees, and remove the 4 pin plug and raise the rpm's to 2200 the timing still reads 8 degrees, not sure why it is not advancing.
