motor mount issue
texsun
My '96 Larson/3.0/Volvo has a motor mount that has pulled/stripped the threads. The one on the front port side that bolts thru the hull. Can anyone help with repair advice?<br /><br />I Really Appreciate the Help!<br />Mark
tommays
Re: motor mount issue
if your refering to were it bolts into the stringer what kind of condition is the wood in rot wood make it strip<br /><br />tommays
texsun
Thanks Tom<br /><br />I really don't know. I looked at the bolt the other day and it had moved upward about 1". I tightened it up some, But it didn't "feel" to good. It never did tighted snug. Is it a lag bolt? Can I simply unscrew it and look down there? I really did not know how or what to look for. Any suggestions or directions?<br /><br />Mark
tommays
it should not cause a problem to take a look unless the engine is supported in some strange way<br /><br />you can probe the area to feel the condition of the wood if you were VERY LUCKLY the wood will be good but the only way to tell is to poke around kind of like termites you dont see the problem till its gone so far it smacks you in the head<br /><br />if there is only minor rot there are products that can be used to stablize the wood if you post about this over in the boat restore area you will get better advise<br /><br />tommays
