Don't fly it. Keep it grounded until you get it repaired
i am easily confused.....but????????????????
Two threads for the same issue aint going to change the answer unfortunately......http://forums.iboats.com/showthread.php?t=531678
You will be doing the steering arm anyway.....that in itself will mean fairly major disassembly work.....you may well be able to get to the mounts once you reach this point.....i would be replacing them anyway, just because.
Not looking for a different answer, its a different question. And yes i have the entire motor disassembled now with power head supported waiting on parts. If you don't have any real information to share you need not reply!
No they are not cheap but i found that they come as a kit now. Two motor mounts and two bolts. Found a set on ebay for $75 brand new.The 60? engines use a wedge bolt entrapment to hold mounts in the bottom of powerhead as they are not on midsection. There a 2 types of mounts and they aint cheap if purchased new.
