Re: Motor or Prop problem; Viking, Force 120 hp (1995)
What prop?Pitch?
Running in a tank with a testing wheel and it gets 5000rpms?
Then your prop and it gets 3000???
Need to do another compression/spark test.
Get a spark tester that measures the strength of the spark.(see pic)
Weak spark will show under a load.In a tank with the wheel it might not.
The fuel system,check it for loose connections,fuel pump diaphram for holes.
The hoses for soft/mushy spots(Ethanol)connectors for sucking air.(see pic)
The connectors in the pic are famous for leaking and sucking air.
