Ok so yesterday I was going from the ramp to a dock to get some bait and while waiting on my buddy at the dock i noticed a drip coming from under the powerhead. I popped the cowl and saw a fuel leak from around the plastic fuel manifold. Motor is a 1996 88 Special V-4. So I though it was from the bottom hose going to the bottom carb. Tried putting a new tie wrap on it and then saw that the leak was from up higher on the manifold. It was coming from the barb going to the hose suppling the primer. In my effort to try and get the hose off and redo it the barb broke off. So to limp back to the ramp I plugged the hose to the primer and used electrical tape, alot of it, to wrap the manifold where the barb once was. No leaks!. Went ahead and ran down the waterway and rechecked. no leaks. Decided to run a while and boat ran better then ever at all speeds. Idled much better then ever. Could I have had a leak for a while, or was air being sucked in maybe?
So now I will get a new manifold so I have use of the primer. Could the primer be leaking fuel into the carb while underway screwing up things? Motor runs great with it out of the loop.
