Motor stalls in neutral
legalfee
OK after replacing the fuel pump, filter, switch box, and regulator / rectifier the stator is bad. Test open to ground on the low and high speed coils. I'll replace it next week. What makes them go bad? It's only 3 or 4 years old. (CDI).
Well----OPEN to ground sounds like it is a good stator.-----Revisit your test procedure / specifications.
legalfee
They can test good but still be bad :(
Jerry, I'm getting conflicting part numbers.
Marine Engine dot com calls for 174-8778K 1 a 9 amp stator
CDI calls for 174-9710K 1 a 16 amp part.
Which is correct?
Serial number is: 0E097208
Thanks,
Steve
jerryjerry05
174-9710K 1 a 16 amp is the one I'd buy.
The Marine Engine one says don't use with bolted magnets.
What flywheel do you have?
legalfee
I replaced the stator and still no start :(
I give up and take it to the shop. I did notice I did not connect the two red wires from the R/R to solenoid when I replaced it.
tg3690
You are lucky you have a shop that will even look at an old Force or Chrysler....
legalfee
Got a mobile marine guy to look at it. He says 1 and 3 carbs have problems but will rebuild all three.
tg3690
Hope that mobile guy does you right.....and fixes your problem. (y)
