Motor year??
Kjeremy2
Re: Motor year??
When your right your right, sorry my bad
Kjeremy2 - You mentioned what it would take to replace the parts in the outdrive but did not mention why those parts were missing to begin with. Don't know how you came about the boat but you might want to make a list of what all the needs are, and what it will take to fix tem. Take that list and add up all the cost to bring it up to speed. You may find it would be best to walk away
Either way iboats will be here to help
So far the motor seems to be intact just a few things that are left to be hooked up. i aquired this boat from a guy that was restoring it and got this far and was too busy to finish as far as i can tell if i don't buy an upper unit for the outdrive and rebuild mine it should cost about a thousand with the major and little things it needs now? i had another boat that had nothing and i walked away after i found out the guy who sold it too me knew it was stolen and sold it anyways so that was my loss. but the fuel line and some bolts are missing the throttle and steering are there just not hooked up and thats as far as i can tell what it needs other than the things mentioned in this post.
alldodge
Re: Motor year??
Looks like I also need to add, the white thing you previously mentioned is not the fuel filter, it's the oil filter. You would have a fuel line going from the tank to the fuel pump (barbed fitting). Then there would be a metal line going from the other side of the fuel pump to the carb. Your fuel filter is part of the fuel pump. It is item 1 and part number 8M0073435
\\http://www.mercruiserparts.com/Show...0&bdesc=FUEL+PUMP+AND+CARBURETOR+(NEW+DESIGN)
Mercury Mercruiser Fuel Pump 2 5 2 5L 3 0 3 0L 4 6 Cyl 861676A1 8M0073435 | eBay
Kjeremy2
Re: Motor year??
theres a white filter on the right side of the block wouldn't this be the oil filter?? there is a white filter on what look like some sort of pump with a big black thick line going in and a smaller black thin line coming out.
Re: Motor year??
What exactly do you have for an outdrive?
Ayuh,... For reference, Look here,...
You oughta be seein' whether the motor runs or not 1st,... No outdrive needed,.....
Jam a hose into the hole in the bellhousin',...
Or,...
Plumb in yer garden hose to the t-stat housin' where the in-comin' water line is,...
Pull the distributor cap, 'n check, 'n clean the points,...
Hook up the wirin', starter, 'n ignition is enough to light it off,...
Splash alittle gas down the carb, 'n see if she'll light,...
What's the oil look like,..?? what level on the stick,..??
Re: Motor year??
In the pictures,..?? Which one,..??
I'm still wonderin' where Fun Times saw the serial number in the pictures, I missed it,...,..... :blue: :)
alldodge
Re: Motor year??
Your correct the oil filter is on the right side and to the right of the fuel pump.
What is the white filter which looks like some kind of pump your talking about? Maybe a pic
Kjeremy2
Re: Motor year??
on the left side of the pic thats the white filter in front of the motor that I'm wondering what it is if its neither fuel nor oil lol.20140115_190337.jpg
thumpar
Re: Motor year??
That looks like a fuel water separator. It is hard to tell. Where do the the lines run to?
Kjeremy2
Re: Motor year??
the thick one comes out of the underneath threw the wall in front of the motor and the thin one that comes off the top of that filter thing goes to nothing its unhooked but very short. by the length I'm guessing it goes in the front or side of the motor. all of these filters are spin ons correct? gonna be ordering them within the next week along with the fuel lines.
thumpar
Re: Motor year??
It sounds like the fuel water separator. The only thing that comes from this area is fuel from the fuel tank under the floor. The oil filter and fuel filter/separator are both spin on types normally.
Kjeremy2
Re: Motor year??
alright so is that different from the fuel pump?? my other question is how do i find the fuel pump filter if its missing and the other i can just bring into say an auto parts store and they should be able to match them right?
thumpar
Re: Motor year??
No, that is not the pump. The pump is the thing on the side of the motor.
Kjeremy2
Re: Motor year??
alright i got ya so that thin line goes into the pump??? then the metal line goes from the pump into the carb.?
thumpar
Re: Motor year??
There are 2 lines that should go to the carb. 1 is the inlet to the carb and the 2nd is the clear tube in case the diaphragm ruptures.
Kjeremy2
Re: Motor year??
oh hmmm ill have to check that out tomorrow idk if there is anything that comes from the carb or not can't remember off the top of my head. so who do i get a part number for the fuel filter since that is missing?? where does the clear tube go back too?
Fun Times
Re: Motor year??
I seen it when I looked over his link to photobucket. There was a red sticker with the number. the number is to old to run the number, that is why I showed it in the links like I did.:)
Kjeremy2
Re: Motor year??
i also can't find the parts on iboats
Part number 32-34423 Fuel HOSE
Part number 49089A1 Fuel DIAPHRAGM KIT
and how come the results for the fuel filter come up as cartridge filters and if thats what they are then how do i get the metal sleeve the slide into?? that part is 35-49088Q2 FILTER KIT
wrench 3
Re: Motor year??
In one of the photos in the link above you showed a serial number of 3252209. Looking up that number in the parts catalog serial number range shows this engine/drive combo should be in the 1972-77 range. I believe your engine model is closer to the 1970 range like in the third link. Hope this helps, good luck.
Something is not adding up to me. I also make that serial number as pre 1975 but I don't believe that they were using the term 3.0L back then??
