- Jul 23, 2011
- 52,460
Motor can be held with 3 bolts to pull the 4th
Whalers have a unique structure. An inner and outer hull are laminated together, then holes are drilled all along the gunnel. An octopus of tubes are inserted and the inner core is filled with a structural expanding foam. Repairs are not as simple as pulling up a wooden deck and replacing stringers and foam.spend a few grand and have the boat restored professionally.
spend a lot of grands and dabble yourself in a repair and possibly never get it right ( depending on your previous fiber glassing , foaming , boat structure understanding, +++++ to do the job that needs doing.
Thanks for the entertaining post. You described my DIY skills perfectly. I will do the bounce test as soon as I find a spotter... that way I will at least have a video to sharenot being familiar with the whaler as such , as Scott Danforth has posted above :
in general ,once water gets in a hull it will waterlog foam , wood , etc break it down and turn it to a heavy sloshy mess .
now : """all is not lost as yet"" , there are options .
bounce test ( as should have been done by now ) i know this could be a bit scary , but at this point , " it is what it is " so a bounce test is only going to tell you how bad it is and how much it will take when out on the water. .
if it is not too bad , there is the option of a transom plate , they are very affective if designed correctly, the boat will run heavy but still work just fine..
tidy it up , and make it safe ,use the boat on inland waterways and close shore fishing etc as is and run it till it falls to bits ( my go to option ) some boats last many years with wasted foam and transom's when used like this..
cut your losses ,sell up and call it a learning experience for you next purchase.
Thanks. I just want to state what I believe you are implying... "If the transom is soaked, then the foam is also soaked". I didn't know if there was a hard break between the transom and the foamed part of hull.The transom is the only wood. But all the foam is water soaked.
While you can extract the water with a vacuum pump, the foam is broken down
Take a big Tupperware bowl. Put a piece of tape on the inside to represent the hunk of wood for the transom. This represents the outer hull shellI didn't know if there was a hard break between the transom and the foamed part of hull.
ha ha , good to see you still got a sense of humor about what you are facing.Thanks for the entertaining post. You described my DIY skills perfectly. I will do the bounce test as soon as I find a spotter... that way I will at least have a video to share![]()
