Mousemobile?
jakecrocker
Re: Mousemobile?
Wire Mesh Screen - WHat size mesh do you guys suggest? Also, how did you fasten this stuff, obviously these little SOB's can get through a lot, Would this 100 x 100 mesh in stainless do the trick?
http://www.bwire.com/
I would think the 100 x 100 mesh would be fine enough for them not to fit through, but also strong enough so that they cant chew right through the wires. Whoever used the wire mesh what did you use and where did you get it?
MrBigStuff
Re: Mousemobile?
Window screen sold at any hardware or home improvement store. Make sure it's aluminum or galvanized steel (any metal) and not plastic.
canoemang
Re: Mousemobile?
I stuff drier sheets all over when there are signs of mice, dont ask me how it works but it does. The bonus is every spring my boat smells like mountain air and every winter my ice house is piney fresh :0
Re: Mousemobile?
in addition to the drier sheets which I mentioned in post #5, you can also shave up a bar of Irish Spring into paper bowls. does the same thing as drier sheets and mothballs. however unlike mothballs, has a fresh scent.
