So Bought a 2001 Sea Ray 182 BR. Got a great deal on it.
190 HP 4.3 Carb model Thunderbolt V Ignition
Good News:
Good Compression
Ran Well on the muffs
Clean inside and out
264 Hours on engine
Areas to improve:
Sat without being run last year. Replaces battery.
For Sure needs a fuel/Water Separator
When on plane at cruising speed engine will cycle between cruising speed and just a bit over cruising speed, Seems to surge for 2-6 second, then even out for 2-6 seconds, then surge again. Will repeat this indefinitely. Does not happen at low speed.
Batt Guage shows between 12-13 volts when running (do I need an alternator or is this normal, my 228 produced closer to 14) this is with blower motor and nav lights on.
Serial for engine is 0M078233 - Mercury oarts catalog has 4 carbs listed for this serial, where would markings be to narrow down the rebuild kit I need?
Other than the Fuel/Water separator what initial maintenance would you all recommend?
Cap/Rotor?
Fuel Filter?
Plugs? (Wires appear in excellent shape)
Carb Rebuild? (If so help please on pointing me to the right place on the carb to look for ID stamps)
Fuel Pump?
Given the above surging problem (More like cycling 200 RPM up and down) Seems to me one of the bowls might be a bit fuel starved. What would you all recommend to get this back into tip top shape and in what order?
Thanks all!
Good News:
Good Compression
264 Hours on engine
Areas to improve:
Cap/Rotor?
Fuel Filter?
Fuel Pump?
Thanks all!
