Pressure rises to about 15 psi when 1st started and cold engine then drops to about 4 psi and never rises again. On the bay at wot or 6000 rpm, overheat alarm sounds after 5 minutes and low water pressure. Tale-tale sprays fine and water is very warm. Alarm goes of when throttled back below 4000 rpm. Water pump replaced and thermostat removed. Any suggestions or ideas? Maybe poppet valve or clogged jackets? Tale-tale good pressure.
