MV-2 Control on 1996 Regal Rush xp120 jet boat
RogerASki
Thanks! Once parts are received it should be straightforward. Then possible shift and throttle adjustments. Maybe next week be complete.
Ski
RogerASki
Received new cc21310 control/shift cable from EBay. Will install on Monday! Keep you posted!
RogerASki
New cc21310 control shift received and installed. Also installed a new liquid tight dome Cap Cable Gland to the 10” tygon tubing connected to the thru Hull connect fitting.
Just need to reinstall the ride plate and test the new control box and make any necessary adjustments.
More photos to come.
RogerASki
Battery on charge! Will try starting tomorrow. In the meantime here's some more photos.
Ski
RogerASki
Have not figured out how to edit after it was posted, but photo of cable on the table should say eye terminal is in middle of photo.
alldodge
About an hour after posting you can see "edit" in the bottom of the posting. This is along side Quote, flag and like. Just select edit
RogerASki
Boat started fine!!! Forward, neutral and reverse seem to be working great! More photos and a YouTube video link to come. Thank you all for your help and support in this project! It definitely was a learning experience!
Best regards,
Ski
PS I still have not seen “Edit” listed under posts. I sent a message to iBoats yesterday for help.
RogerASki
Hi, I did see the Edit immediately after I posted but it went away, as you can see in previous posts. Thanks for your help though. Working on YouTube video. Will post link soon.
Thanks for your support.
Ski
RogerASki
After rechecking ride plate, and repairs in general, I took her out again and creeped the speed up to 40mph! There was severe vibration! I thought I might have hit something, so I immediately put at idle speed and went back to my boathouse and put her up on the lift. I did not find anything out of the ordinary. Ride plate and screws still tight! Hull looked normal.
Will check out position of gate at full throttle, neutral and reverse on Monday!
Does anyone have other suggestions for vibration at high speed?
Thanks,
Ski
alldodge
Most vibrations come from something rotating, so that is the motor, drive shaft or impeller.
RogerASki
Today’s update - attempted to adjust the gate in forward. Unfortunately, the Stop Reverse Gate and bolt are missing. So the next step is to drill out and replace. New parts have been ordered. Keep you posted!
Ski
alldodge
Who needs to go reverse man, that be going the wrong way :D
RogerASki
hahaha!! It is actually the port side stop! Should be here Sept 25! In the meantime - tomorrow will start trying to remove broken off M8-30 bolt. I’ll use Speed Out and my portable drill. If it doesn’t work I’ll have to pull her out and do in on my driveway! At 107F today not a great choice!
Keep you posted!
RogerASki
Removed the reverse gate stop washer broken bolt. Please see photos. Now waiting on the new stop washer.
