Corjen1
- Aug 24, 2013
- 1,237
Sam, there are only a couple kinds of boating folks, ones who have forgot to put the plug in, and those that lie about it!!!
Here is todays update....
Teak oiled he swim step...
Installed travel chains on the bow seats...
Ran the ToP for about 30 mins on the muffs...adjusted the RPM gauge, had it set wrong. Volt gauge is reading 10.5 volts, but has 12.6 to it... not sure what up with that. At least I know the battery is getting a charge. Also rigged the reverse gear.. not more ticking!!!! While the lower unit lube was hot, drained and re-serviced it.
(Click on image)
Should the fuel filter be completely full while running? motor ran fine at idle-1500 revs. Didnt go over that. Seems to me like it should be full though.
(Click on image)
