Re: My 1972 65 hp died while running.
Here are the tests for the timer base ....
Checking Sensor Coil
a. Disconnect sensor coil leads from power pack terminals #8, #9, #10 and #11 (common lead). Connect ohmmeter (LO ohms scale) to each sensor coil lead (white with black stripe). Connect other ohmmeter lead to the common lead (black with white stripe). Meter should read 8.5, plus or minus 1 ohm.
b. With sensor leads still disconnected from power pack, connect ohmmeter (HI ohms scale) alternately between each sensor lead and ground. Infinity reading indicates good sensor. Zero reading indicates leads or sensor coil is shorted to ground and should be replaced.
c. The sensor coil and timer base are serviced as a unit.
Note: Power pack terminal 1 - 6 are on the left side, facing it.
