Re: My 1994 johnson 225 back fires/ sneezes at idle
Yep whole front of the motor is disassembled down to the block ... waiting on a reed block gasket, new manifold, carb, and throttle body gaskets are in and I picked those up yesterday. Funny how a $3
part can hold you up ... :/
GREAT INFO Daselbee I appreciate the help !!! I think i'm gonna have the local shop do the link and sync I feel like I owe them for all the help they've been and they said it'd be 85 bux might be $$ well spent. That MAY have been the problem in the first place because the previous owner did take the carbs off and may have taken the throttle bodies off as well.
Yea I know EXACTLY which screw you're talking about because I ALMOST couldn't get it off it's on the bottom middle of the upper intake and yea TOTAL PITA! I know this because I only REALLY wanted to take the upper manifold off and leave the lower intact HOWEVER that particular bolt decided that it wasn't gonna go down like that .... I always try to put all the screws in stuff first running them down til they just touch and then run my torque pattern but i'll keep all that in mind when I'm reassembling tomorrow top manifold first ... the reverse of how it came off.
As far as the reed block goes mine only has two hex head screws holding each one on and I'll use some weather strip adhesive upon reassembly.
Where can I get that stuff at? Is that the stuff they call elephant snot??
So, you got it apart, and are waiting on parts? Is that the status right now? If so, here are some tips in re-assembly: 1. Reed block gasket is a long rectangle. The "long side" of that gasket tends to squish out , or bulge out, after you install the 4 screws that attach the reed block to the intake. It doesn't squish at that moment. It waits until you have it all back together, then it squishes out:joyous:. I always use an adhesive to glue that gasket on better before assembly. I use 3M yellow weatherstrip adhesive very lightly, wiping up any excess if it oozes out. The symptoms if it squishes are this: Massive gas raining out the front of the carb when running. Just remember which reed gasket you replaced, and if that carb is raining gas out, then reed block gasket has squished out. 2. On that intake....I forget which screw it is.....but there is ONE screw that has interference with the casting of the intake, that you cannot get a socket on. You have to assemble that screw first, before you , say, put the upper intake on (or lower) I forget which....but there is one screw that is a PITA. It is lower center either on the upper intake or on the lower intake. If you don't do it first, you will have to remove everything you just assembled just to get to it to put it on and torque properly. PITA. 3. You may not think about this, but once you remove and then re-assemble the throttle bodies, you MUST re-sync the throttle butterflies. Just the simple R and R of those bodies, can, and usually does, throw the butterflies out of sync, most often a butterfly will be slightly open on the bottom two cyls. Sync the throttle plates/butterflies with the black carb bodies OFF. You can see the whole thing way better. All butterflies must be completely closed, and operate in exact sync with each other. Perfection is critical here for proper idle.
