My 1997 150hp rebuild
pointblank1000
Thanks
What is the bias circuit and you mean the
Idle speed control?
It sounds like the idle speed control box failed causing the switch boxes to fail.
ALSO I found the wiring harness 20 amp fuse blown.
Faztbullet
Bias circuit is in the switchbox and keeps timing on both switchboxes the same. Advance/idle module plays with the bias to ground circuit to advance/retard timing.
