Re: My 85' Riviera Tri-hull Rebuild
New question:
I am still working on my motor, but one thing I didn't mention is that the boat originally had a kicker plate on the back of it...
(The thing (bracket) is pretty much disgusting to look at, but I am sure if i sandblasted it up and then gave it a good zinc chromate prime and then paint. (Its aluminum, and I could even match it to the engine color), It can look pretty decent when finished... but here it is for now... (pics below)
Bracket:
Bracket:
I have a 15hp 4-stroke Honda for my jon boat... I think it would make an excellent kicker for a larger boat, but it may be a bit too big/heavy for this one... (weighs around 100lbs ish).
1. Do you think this is too much of a kicker for my boat? (boat weighs about 400lbs empty hull, 650 with the main O/B, probably 900 with everything in it and fueled up).
2. Would this put too much weight to the rear of the boat? (it will have the main O/B, two batteries, and two 6-gal. tanks all at the arse end of the boat)(then the extra weight of the kicker if I add it).
3. Do you think this old bracket will support the weight of a 15HP 4-stroke?
(I have no idea what it was for originally), or should I invest in a new one (which I don't have the money for).(If you think the 15HP would be ok as a kicker).
My main O/B is a 77' evinrude which I have never had in the water... and I'm a bit leary of it until I get some water time on it, (starts and runs ok on the stand, but won't know for sure till its in the water). So it would be nice to have a good backup that I know runs perfectly... but I am debating the pros/cons of adding the bracket back on...(more holes in the transom, the extra weight, etc.)
Also as a side note, I have a 44lb thrust saltwater Trolling motor I am going to bow mount as well for fishing, so worse case I will have an electric backup if nothing else.
So what do you all think?
/edit - also now is the time to do it if I am going to... while I am sandblasting and painting the rest of the motor...
