Re: My Boat Pushes at Full Speed
Generally, having the boat ride on the aft 1/3rd is fairly ideal, the rest of the boat should be just out of the water. It shouldn't be pointed at the sky however. While I still feel you are overpowered, I am running 125 horses on a 16.5 length boat. It is, however, rated for 145 horsepower, so I am well within spec. Part of the reason your boat has such a low horsepower rating also is because the heavier motor eats up too much of your weight capacity, and also may prevent the boat from staying at the surface if it gets swamped (assuming it has floatation foam). If you are planning to keep the motor, there is no law that says you need to be running wide open all the time. You may want to try to set it up for optimal cruising at the expense of all out speed. Do you have power trim? The cavitation plate should be within 1 inch of the very bottom of the boat. Normally I would say for you to have it mounted a bit above the bottom of the keel, but I have the feeling you are already going too fast with not enough boat around you, don't need to add to it. If you have power trim, then you need to always be adjusting it based on speed and water conditions anyway. There isn't really a magic one position that does it all, which is why power trim was developed. Anyway, good luck and use caution...
