My control lever is ready to fall off??
joetheis
Just getting my boat "water ready" My firdt motorboat, (I'm a sailboat guy).
This is a Silverline, 1980, with a Merc 220 V-8 and 1st gen outdrive.
The lever has 3 buttons, "down" under handle, on handle one on each side for "up"
I had it out for the first time last weekend to see how it ran, and I noticed I can pull the handle off the spline shaft.
I took the ring off the handle to see if there was a screw or??, nothing.
I was about to dive deeper into it when it started to rain and I called it.
The boat (now) is in Clayton N.Y., and I'm 320 miles away in Scranton!
I MAY be going up this weekend, (it looks like rain, so maybe not).
Can anyone help?
How is this handle held on???
Thanks
Joe
It's true! A boat IS a hole in the water where I throw $$ into! ;)
dubs283
Re: My control lever is ready to fall off??
don't know what kind of handle it is, there are a few different styles that used the trim button set-up you have
its probably so old you can't get parts for it, probably time for a new remote control
thumpar
Are you sure it is coming off the splines? I had a control that pulled out from the side to get to throttle only.
Either there is a bolt missing that held the control handle or look for a hole in the bottom of the handle, there should be a allen head set screw there to tighten the handle.
Ayuh,.... I think That's the answer Right there,....
