My First StarCraft; 1975 18' SuperSport
GA_Boater
Re: My First StarCraft; 1975 18' SuperSport
Wondering if you can find a pre-welded spring perch axle with the right 11/16" difference? You might need to get one with loose perches and weld them to the right spacing yourself or at a shop.
badbarracuda
Boat looks GREAT! There is some amazing work done on this project.
classiccat
"Captain" + Starmada Splash Of The Year 2020
My understanding is that the spring block (thing that keeps the u-bolts in position) is loose...and doesn't get welded until you specify the spring-centers.
Thanks BB! Slowly starting to come together! :thumb:
classiccat
Brown truck made the drop!!
Here's my process for laminating the 2 pieces of marine ply:
  1. Clamping dry run (Done...realized that I didn't have enough clamps!)
  2. Sand bonding surfaces with 80-grit.
  3. Clean the surfaces with denatured alcohol & clean rags.
  4. Heat the surface with my heat-gun. <=maximize penetration of wetting epoxy w/out solvents
  5. Apply plain/thin epoxy to both mating surfaces.
  6. Wait ~ 30min for wood to absorb epoxy wetting layer.
  7. Mix-up the glue layer of epoxy/cabosil to a catsup consistency.
  8. Apply a uniform layer of the thickened epoxy to the bottom piece of transom PLY <=Using a notched spreader
  9. Overlay the other section of transom PLY.
  10. Lightly clamp <= Avoid starving the joint of epoxy.
  11. Take pics while enjoying the aroma of curing epoxy! :thumb:
EDIT: Yes to using a notched spreader.
Watermann
12. 10 bucks for gorilla poly glue, wet rag to wipe down one side, spread even coat of glue on other, clamp, no smell, walk away to have a beer. :D
classiccat
<= Not in my house Agua!
:p
ctswf
^ hahaha!
hey blue looking good!
ctswf
Hey! Thanks for swingin' by Ct! Any striper action yet!?!
Not yet, I'm getting all setup with the boat work I never finished last year. MBS is in full force right now I'm trying to resist it
Watermann
Hey BF have ya raised a stink in the garage yet? :rolleyes:
classiccat
The only "stink" in my garage occurs when I eat Burger King onion-rings prior to bucking rivets. :target:
Straight epoxy (i don't cut mine with solvents) is actually quite pleasant to the senses...and Admiral approved! :thumb:
SigSaurP229
I dont cut epoxy at all either just can't bring myself to thin a waterproofer
Watermann
^ :lol: :eek: :lol: ^
So no pics I would have to say that's a no.
barato2
one area where i still will have to differ from you guys' expertise.....i think you get better waterproofing if the outer mm or 2 of plywood is completely saturated with thinned resin, so i still thin mine as much as 50/50 or even 60/40 so it soaks in and fills in between wood fibers. use less solvent for the top coat if you want, but the resin saturation actually stiffens the panel noticeably long before you get any build on the top surface. it is slower doing it this way, but i think it's worth it. i'm not trying to coat it so much as incorporate the resin into the wood.....so there's no room for water to soak into the wood. a gouge in your coating and all protection is lost if you just coat it on the top surface, but this almost makes the outer layers of the wood into sort of a composite where the wood fibers act as the "glass cloth".
you may recall the NatGeo project a couple of years back on the sense of smell, where they determined that it's no illusion that the memories of odrs stay with us longer than most anything else? for me, the smell of straight epoxy always takes me back to Cub Scouts and school science fairs (gluing fossils onto a board)....
classiccat
well..this is what they look like:
images
you'll have to use your imagination on the "aroma" produced when they react with my gastric system :p
You're the man when it comes to cutting Epoxy B2! What you say makes sense.
I have a few West Systems guides that recommend against using solvents...but rather heat the wood to promote infusion.
I'll be using it as primer for both bonding and glassing...future tense therefore no pics yet :lol:
SigSaurP229
At the end of the day while we all have different ways of doing things anyway you spin it they are all superior than most and are all superior to factory installation
Watermann
Oh man, think I'm gonna have to pass on the nasal appraisal of your rings and stomach juices. The epoxy resin sounds a bit more appealing now.
Weep'n Willy
Master Chief Petty Officer
White Castles or smoked fish with several wobbly pops will most certainly rival any BK onion rings!!
jbcurt00
Yep, White Castles w/ extra Dusseldorf mustard at 3am, onion rings and a chocolate shake :hungry:
Then of course :horn:and please roll down a window :painkiller:
