Re: my lower end is very messy
Hi...these old motors, running at 24:1 gas and oil, will make your test tank look like the ****ens pretty darn fast. They're pretty messy that way.<br /><br />You really should replace the water pump impeller and change the lower unit oil, along with installing new plugs.<br /><br />The impeller is Sierra Part number 18-3083. You can get it at a local NAPA dealer, or order it from this place:<br /><br />
http://www.marineparts.com/sierra/sierra170.aspx <br /><br />Visit your local marine supply store and buy the lower unit oil, complete with the pump. You fill the lower unit from the bottom, and the pump has a fitting that screws into the drain hole. You should be able to buy the gaskets for the drain screws at the same place.<br /><br />NOTE: DO NOT REMOVE THE PHILLIPS HEAD SCREW ON THE BOTTOM OF THE LOWER UNIT! The drain and fill screws are slotted, and larger.<br /><br />Once you've done that (do buy a manual for this engine. I recommend the Seloc manual, available here on iBoats.com. The one you'll get as a factory manual is a multi-engine thing that can be confusing for a newbie. The Seloc manual, with its faults, is easier for a beginner to understand.<br /><br />If your motor is running, reasonably well in the tank after you do this stuff, then don't fool with the carburetors at this point. Put it on the water and give it a test run. It may surprise you. My '58 RDS40 35hp motor (essentially the same as yours) didn't need any carburetor work at all.<br /><br />For your first on-water test, though, do try to have a friend with another boat along. If your new old motor dies in the middle of the lake, you'll want a tow. It happened to me on my first test run. I was fortunate enough to have another small outboard on the boat and got back to the dock OK, but if you don't have a kicker motor, have a friend in another boat along. It will avoid embarassment.<br /><br />Best of luck with your new old outboard!
