Sunsetrider
- Jun 12, 2011
- 299
I intend to replace my driver side lounge seat with a pedestal/capt. seat and i've bought the pedestal with rotating top. It's 14-20 inch swivl-eze with a 9-inch base. I've yet to choose a seat. I hope it isn't too tall but after testing it in the boat (with a jump seat cushion) I think it'll work out fine.
Biggest concern will be the mounting method, and I am challenged there because of my unfamiliarity with boat construction. The dwgs below show (2) the 9-in. base with 6 bolt holes and in blue, the 3.5 in. hole I will cut in the floor, (1) the aluminum plate I will have made up to secure beneath the sole I messed up the upload order), and (3) the 2 superimposed. The idea is to place the plate in position through the 3.5 in. hole, then use epoxy or marine sealant to place a nut under each hole in the plate (lined up with the holes in the ped base).
Or am I going too far and should just use fender washers at each nut position? Will there be 9 inches clearance between stringers (the ped is to be placed in the center of the stringers which are used to anchor the lounge)?
This method seems to me superior to glassing more plywood on top of the deck as some suggest. And avoids the mess of glassing which I want to avoid.
Opinions sought!
here are the "design pics":
Opinions sought!
