My Super Sportster
Status
Not open for further replies.
dozerII
Paint is looking real good, I like all the green grass in the background.
GoldDuster360
I need to see the dentist now... :lol:
Hey I'm really liking that color, check this out... Transom and pieces for my SN dash
Nice
GoldDuster360
So after carefully taping up the steering cable and boot for the repaint I ended up replacing them. Not bad for 33 yrs old but looked to be on borrowed time.
It was 13.5 ft long, next closest size available now is 14 ft, they don't offer them in 1/2ft increments any longer.
64osby
I would look to replace it as part of the project. Breaking a cable on an outing would be a real pain.
Watermann
New cables shift and operate so nice and with peace of mind to boot. Good choice on replacing them. Even if a little long the cables can be moved around to take up the slack unlike a steering cable.
GoldDuster360
It turns out the new QC Safe T Helm has a larger diameter snout on the die cast housing for the steering shaft support which requires the newer style mounting bracket with the larger through hole. The marine supply store where I bought mine inadvertently gave me the old style one with my new helm and cable. No big deal, I just opened up the hole slightly with a die grinder to allow the new helm to pass through it, was not worth the trip back to Ft. Pierce to exchange it. I really like the Quick Connect feature, it made the process of getting the steering wheel spokes centered the way I wanted them a snap. No tools required, so you can make this adjustment out on the water quite easily.
GoldDuster360
All that trouble to tape this thing up and now I'm going to toss it. Just didn't make sense not to replace it while doing the new cable. It had a steel inner ring that was getting bubbled up under the rubber. New one has no metal in it except for the rivets!
64osby
Good call on replacing that. Saves the new cable for wearing.
GoldDuster360
I also made sure the bare aluminum underneath the transom pad got properly sealed up. Two coats SE primer, 2 coats epoxy primer, 3 coats catylized enamel. I used 5200 to seal the new pad in place.
LastDollar
Just read your post while having a cup of hot chocolate :rolleyes: , That is a sharp looking boat, keep up the good work!
GoldDuster360
Thank you for the words of encouragement. I have been cleaning up/fixing this "Turn Key" boat since last October. Starting to run out of steam and the warm weather has already hit us down here. Freaking humidity is back. Here is a shot with the transom pad in place:
Watermann
Looking good GD :thumb:
What are your plans for the transom cover?
Watermann
Yeap, I didn't know if yours was still in good shape or not, most get seriously mauled and broken since the AL is so darn thin. Looks really nice though from here!
GoldDuster360
Yeah, this was my Dad's suggestion, he put them on all his boats, the stainless really saves the transom from the clamp feet. He made two of them for me, the smaller one is for the trolling motor. I made a matching plywood outer transom pad for the trolling motor as well. Just about have this boat all buttoned up, both the engine and trolling motor are hanging back on the transom.
Tnstratofam
Is this what you were thinking?:
Just getting caught up after being offline for a few days. I like the idea of the inner transom cover. I didn't think about doing something like that to mine when I finished ours up last spring. I may have to do some modifications to ours this spring. Looking good, and I'm sure you like allot of us can't wait to get her back in the water.
GoldDuster360
Can't wait to get her back out on the water, haven't used her since late December. Here she is all re-rigged and ready to go:
GoldDuster360
I also got the tach wired in and working good, used a factory wiring harness found at a marine center, it was ten yrs old, new in box. Got it wired into the light circuit too.
cj8mule
Very nice work. My hands are shaking also..... it's time to go fishin'
Watermann
She's looking great GD and coming together nicely! :thumb:
Status
