- Jul 18, 2011
- 19,103
I thought that I would test out the new iBoats Forum Site with a post about my winter hobby/sport . . . Snowblowers
For the past few years I have been expanding my 'fleet' of snow blowers . . .
I've had a 1988 Toro 521 for quite sometime. Got from a family member who could seem to get it to run. 30 minutes later, I had a running machine.
Then the machine 'ate' a scarf that was hidden under the snow, and I thought the machine was a gonner. so, I picked up a Troy-bilt 2410 (24" 5 HP) machine. I then was able to fix the Toro and had 2 working snowblowers.
Also added a combo Volt/RPM/Hours meter . . .
I then had a spare engine from the Troy-bilt, looking for a good home. so, I got another Toro machine that needed a new engine.
While replacing the engine, I took the machine apart and re-painted everything.
I sold the second Toro (Model 3521) last week and plan to use the $$$ to buy a bigger Toro machine (Probably an 824 model)
Along the way I have come to realize . . .
1) Snowblowers are pretty simple mechanically
2) The engines only idle down to about 1600 RPM vs. the 600-700 that we are used to seeing with boat engines.
3) Maximum (safe) RPM on these engines are about 3600 RPM. . . otherwise the oil system cannot keep up and the connecting rod seizes/breaks (Boom !!!)
4) Most of these engines are set with a governor that tries to keep the RPM constant by opening/closing the throttle as the load on the engine increases/decreases. . . this keeps the engine from over-reving when at full throttle and no load.
Most snowblowers are powered with single cylinder engines, even in the 6 -18 HP range. By contrast most outboard engines in that same range will have twin cylinders. I have been thinking about taking a powerhead from an 8 HP outboard and retro-fitting it to a snow blower. I would imagine with 2 cylinders, it would run a lot smoother and idle down below 800 RPM.
