captquest
- Jul 1, 2008
- 120
I am lucky enough to own one of those wonderful force engines. Mine is a 1998, 120 horsepower. I have a little mechanical experience and don't mind working on my own stuff (good thing). I have had this motor (and boat) for two years and this is some of what I have done so far in that time.
Replaced starter (twice, they fried while trying to start with fuel problem))
Replaced flywheel, stator, and trigger (flywheel broke and damaged other parts)
" fuel pump, all fuel lines and added water filter
" impeller
" lower unit seal
" trim relay switches
I have rebuilt the carbs and cleaned out the fuel system
Over all though I have been out on the Bay and Gulf beaches dozens of times with no problems. I have logged many hours on this engine (and boat) and have only broke down two times in the water. Last night I popped the cylinder head to clean the carbon deposits and replace gasket. I noticed the bottom cylinder was a bit gunkier than the the others. After a little research (Iboats is great) I learned that my exhaust plate gasket may be leaking, and it's supposed to be a real pain to replace (from what I read). So here I go again.
Well I guess I posted this to attract other wonderful Force owners that would like to share their experiences. And if any one knows about the exhaust plate gasket issue, I would appreciate any info.
BTW my Key Largo boat is really wonderful, I wish (some times) I had a Yammy on it
May the Force be with you.
Well I'm getting other opinions on that exhaust gasket now so I'm a bit confused about it. I'm hearing every thing from weak spark to Ethanol damage? Any help would be appreciated.
" impeller
" lower unit seal
