Need a closed water cooling system
bzuchero
I boat a 1988 Seaswirl with a cracked block and head because the previous owner did not know much about winterizing. I bought a long block 5.7 and want to do a closed fresh water cooling system. Has anyone out there taken a raw water system and converted to freshwater cooling? Any reputable manufacturers you can recommend?
Don S
bzuchero
Re: Need a closed water cooling system
Thanks Don. I will be using the boat almost entirely in Saltwater.
Don S
Yeah, with a new long block, that's the time to install one.
tpenfield
I did, I did . . .
"San Juan Engineering" and "SeaKamp" are the prominent aftermarket guys . . . I went with SJE, but they are both fine.
I ordered the kits through Michigan Motorz, like what Don mentioned.
Here is a link to my web page about installing them, etc.
Closed Cooling Systems
LorenHaus
I did, I did . . .
Great job on the write-up of your 7.4L MPI closed cooling system install!
