I noticed last season that the lower unit lube was cloudy and I want to replace the lower unit seals. I have removed all the bolts (2 on each side, 2 (one long and one short) under the trim tab. I also freed the shift rod under the carbs. The lower unit will not separate from the upper unit. It is loose but the separation is approximately 1/16th of an inch. I spoke to the guys at the marina and they said they drive in wedges to split the cases. Is there a preferred spot to insert the wedges where I won't crack the case?<br /><br />thanks,
