Need feed back please...
Limited-Time
Re: Need feed back please...
DN,<br />You contracted with the Marina to winterize your craft. They accepted the contract and received payment for their services. It was the Marina's responsibility to insure your engine was correctly winterized. They now say the job was not done correctly and consequently the block froze. How can they now deny responsibility? Ask the Marina what happened to the antifreeze the reportedly put into your engine. Then ask them how in a “typical winterization” they know when the antifreeze is throughout the system. My guess is they see it coming out with the cooling water. At least that’s how I have done it in the past.
TilliamWe
Banned
Originally posted by DN:<br /> The saga continues...can someone tell me if during winterization are you able to tell if the engine is recieving and circulating the anti-freeze? Marina is saying " head is blown as a result of the water pump (probably on its way out end of last season) breaking up and plugging the waterneck resulting in no antifreeze getting thru during winterization ultimatley causing a freeze up"<br />Once again thanks everyone for you valuable feedback!
Wow, they are really stretching & searching for an answer that doesn't put them at fault.<br />Maybe what they said could have happened. But there are far simpler explanations!<br />Is there another shop around that can give you a second opinion?<br />Where's the water pump that they replaced???
jmccall001
Just a sugestion - being bill collector in my past life has provided some experience here - get a small recorder when you ask questions - if the marina does not want it recorded, tell them it is to make sure the YOU(the customer) can understand what is being said and not misquote the marina.
Scaaty
I read half of the posts. They will not admit they screwed up, and they didn't do it on purpose. Best bet is to be nice, get it fixed, ask for some kind of reibursement as it ran fine when you took it to them, gets it fixed, and go on with your life.....stuff happens...you were just the next in line...its called life.
Davefasinc
Marina just called and said they had bad news..they just finished there tear down and the engine is toast...heads are gone and engine block severely cracked. I'm meeting with them in the morning..
salty87
i agree with olbuddyjack. if there was something wrong with your baot that prevented successful winterization, the time to tell you about that was then. not now. <br /><br />if they're paying attention to what they're doing, they can tell that anti-freeze is going into the block. does your receipt say anything about using a certain number of gallons??<br /><br />their failure to notify you is tantamount to accepting the liability...if the stmt that a faulty pump caused it is true. <br /> <br />either way, they failed in their obligation to successfully winterize it. you successfully held up your end of the deal by paying.
Northern Eclipse
Check with your insurance company and see if you have Freeze protection, I do with my insurance but only if the motor has been winterized by a certified marine repair.
Davefasinc
TilliamWe..taged and baged at the marina. Thank you all for you advice/opinions I feel more educated which will help me with dealing with the boat issue and the marina.
rogerwa
I don't know about you but when I winterize, I not only ensure that the AF is coming out the exhaust, but I open the block drain and ensure it is bright green and I also checked down the thermostat hole. If any of these things were done, they would have found the problem.<br /><br />also, if the WP was breaking up, wouldn't the engine get hot and overheat??<br /><br />They are liable.. don't let them off the hook..
lakelivin
I went through a somewhat similar situation where I think it was even clearer that the repair shop was at fault. Also had a time lag between them causing the damage and having it formally diagnosed.<br /><br />I'd recommend that you NOT just drop it. Instead, negotiate with them on a good faith basis. Let them know you've talked to several other marine mechanics and that you know that some of the stuff they're trying to feed you is B.S. (maybe state it a bit more diplomatically than that, lol).<br /><br />I also think it would be worth taking it (with all the old parts) to a different shop for diagnosis & repair estimates before making a final decision as to how to procede. Hopefully you can find one that will be completely honest and not worry about ruffling the feathers of a 'colleague'. <br /><br />Keep Small Claims Court in mind as a real option if you can't arrive at an acceptable solution with the original shop. As far as an acceptable solution, determine what your bottom line is w.r.t. how much $ (if any at all) you're willing to pay to cover any portion of the repairs that they won't. This is a personal decision, weighing the money vs. your time, effort, and the stress of taking it to small claims court. <br /><br />If you do reach an agreement with the original shop, GET IT IN WRITING BEFORE YOU LET THEM DO ANYTHING TO YOUR BOAT. This should be very specific w.r.t. what they will do & pay for and what you agree to pay for (INCLUDING A MAXIMUM $ AMOUNT).<br /><br />Don't be afraid of small claims court. If you do go that route, at the end of your neotiation with the shop, politely let them know that you can't accept whatever solution they offered and are going to take the matter to "arbitration" by an independent third party (i.e. small claims court). Make sure you take your boat & old parts with you at that point, if you haven't already. <br /><br />Make sure you're thoroughly prepared w.r.t. documentation. This includes all paperwork & other materials supporting your position. Hopefully you can get the independent shop that verified your diagnosis to accompany you to court. If not, get them to give you a signed, notarized statement on company letterhead supporting your case. If you've got witnesses that can verify your account of how the boat ran the last time you drove it before taking it in for winterization, when you first launched it the following spring, and what happened on the water after launcing, bring him/her to court with you. If you absolutely can't get them to accompany you to court, again, get a signed, notarized statement from them & bring it with you. <br /><br />Get a copy of the OEM Owners & Service Manuals and mark/ highlight the sections that describe proper winterization procedures and consequences if done incorrectly. Hopefully there will be a line that specifically states that the engine block is subject to cracking if winterization isn't done properly. In court, be polite and unemotional (to both the judge and the shop representative). State your case, provide your documentation, and hope for the best. <br /><br />One good thing about small claims court in your case is that you'll be filing against a business and stand an excellent chance of collecting any award you might win.<br /><br />Good luck. In my case, I was awarded half the amount of the damages I asked for. Basically, I had thought I'd worked out an agreeable solution with the shop, only to find out that in the end they were going to charge me over twice what I thought the agreement would cost me. But since I didn't have any specifics in writing, the judge felt I left myself 'open', and split the amouont down the middle. More info on my case is in the following post if you're curious: http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=008398 <br /><br />EDIT: also, make sure you memorize the information posted by others above to counter some of the shops dubious claims, whether during negotiations with the shop or in court if it goes that route.
