Need force prop
fisheymikey
hi!
I have a force 125 1988
I want a 17 pitch I want a 15 stainless if possible...
ebay EDIT
mike
alldodge
Re: Need force prop
hi!
ebay EDIT
mike
Iboats has the props for your motor. I take it you want 17 pitch aluminum and a 15 pitch stainless or did I miss something?
Would also need to know if your outboard is a single exhaust or dual exhaust
fisheymikey
Re: Need force prop
im sorry... I mean I have a 17 pitch and want a 15
jestor68
Re: Need force prop
Google Propco Propellers.
They list aluminum and SS props for that motor in 15 pitch (as well as other pitches).
Frank Acampora
Re: Need force prop
Your 1988 is a single exhaust, one piece lower unit. You can use stock type closed hub props or open thru-hub exhaust props. There will be no difference in performance.
HOWEVER: Before you go spending money on props, tell us what boat you are powering, if possible, full throttle RPM with this engine, top speed, and what problem you are trying to correct.
fisheymikey
Re: Need force prop
View attachment 219187View attachment 219188View attachment 219189View attachment 219190View attachment 219191
I have a bayliner trophy deep v
max rpms are 44-4600
I really need that extra torque because I found in the ocean it was struggling with strong currents and bigger waves.
I want when I touch that throttle I want to get out of there...
and yes it is a one piece single exhaust
also I want a used one there must be hundreds out there but here in quebec no scrap yards
thanks
Frank Acampora
Re: Need force prop
The force 125 is not a particularly strong engine and with the 17 pitch prop, yes, you are at the bottom end of the recommended RPM range. The engine does better at the top end of 5500 RPM. So yes, you probably will do better with a 15 pitch prop. If you find an after-market prop, be careful: While some are listed for Force engines, you may need to modify the prop a little , or modify the anode behind the prop, or you may need to remove the anode completely for clearance.
Going down two pitches to a 15 should boost RPM up to about 5000 and if you go stainless (except Ballistic, it loads down the engine even more than stock) you should see another 200 over that.
If you can't find the prop you want and if you can find a 2 to 1 ratio lower unit, bolting it in place of your 1.7 lower will improve performance a good bit with your current prop.
jestor68
Re: Need force prop
If you google "Force 125 owner manual"; you'll find a PDF for a Force 85-125 owner manual to print out.
It states your WOT rpm range is 4500-5500 rpm.
SkiDad
Re: Need force prop
sounds just like how my boat was when I got it - ran about 4500-4600 rpm with the 17 pitch. I put a new 15 pitch AL prop on it it went to 5000-5100. I run about 2400 lbs typically. I have a stainless 15 pitch that only gets me 4800 b/c of the cupping but does have better low and mid-range acceration. My hull runs better with the AL prop.
alldodge
Re: Need force prop
I would suggest sticking with an aluminum prop because 125HP is not enough power to flex the blades much if any. If you hit something, you need a prop repaired, if it was stainless and hit something you may have a lower unit to fix.
