sorry for the lenght. just installed a lcx-27c in my skeeter. i have a lms 480 on the front i want to network the two. of corse the cable is on back order from lowrance well i have an old blue cable so i decided to cut it open and ohm it out. i compared it to the blue to red cable here is what i found.....
network converter cable blue to red ohmed out
blue----------------------------------------------------red
pin 1 black (-)----------------------------------------pin 3 nema 2000 comm
pin 2 red (+)---------------------------------------pin 2 nema 2000 power
pin 3 blue---------------------------------------------pin 5 nema 2000 comm
pin 4 drain--------------------------------------------pin 1 nema 2000 gnd
pin 5 white--------------------------------------------pin 4 drain
does this seem correct? the reason i ask is because i use a connector at work manufactured by turck that is the same as the red nema connector. i want put the connector on on the blue cable. is there a good web site out there for this type of info. and to take it one step feather can i make a cable that will connect to my 2005 yamaha 225 hpdi.
If any one to know the part number for the turck connector i will look it up on tuesday and post that information.
thanks guys
jim cav
if you want to talk email me your phone # to procraft118@gmail
thanks guys
jim cav
