Woodonglass
- Dec 29, 2009
- 25,930
Depends on the temps when painting The majic reducer is for temps in the 80's If cooler use acetone if warmer use mineral spirits
Did you read the link that was posted earlier?
I did, I opted out not using any hardener since the Tractor supply near me didn't have any available in store. I needed to take advantage of the sunlight as much as possible and not wasting my time running around picking up additional materials. Im not in hurry to get the boat in the water so I'll have ample amount of time for the paint to cure properly prior to cutting & buffing. To be honest, the paint is already looking good without having to cut & buff, it's not a show boat.
I'm absolutely CERTAIN that your paint job will NOT be satisfactory since you decided NOT to use the Hardener. It will Never cure to the needed hardness and will easily be scratched and damaged. The hardener is sold at a multitude of places, and if you would have informed the members here on the forum they would have directed you to other sources. What prep methods and primer paint did you use?
Oh my, I think you will regret not using the hardener. Why? Because the hardener changes the paint chemistry to make it more impervious to fuels and oils and of course scratches. I hope you don't have any real issues with those. I am sure the pinat finish will work out well, but I am not so sure about the longevity now. JMHO
You can use hardener on the next several coats, but...be aware that the final coats are at the mercy of how well the previous coats adhere to the substrate. IMHO I'd recommend a thorough sanding with 180 grit prior to applying the paint with hardener. This will allow the GOOD paint to get a good BITE into the previous coats. Check with your local Paint Stores that Sell Auto Paint. They ALL have the Acrylic Enamel Hardener and it WILL work just fine with the Rustoleum.
Read the link. It has all the info for mixing and applying the paint. 60 ml of hardener per 500 ml of paint. Add the hardener to the paint first mix well let sit for 10 mins then mix again let set for 10 mins mix again let sit for 10 mins and then thin with acetone. and apply.
Yeah, When I was trying to paint my boat several years ago, I struggled with Rain and TORNADO's![]()
