Need Help I can’t get Johnson 55hp Motor to run right at all
In my opinion when you acquire a 50 year old motor you need to do a complete evaluation before spending any beer tokens.---Post actual compression values here.----If around 140 PSI ,look for and find a used lower unit.
brodyg201
yeah i’m still waiting on a compression tester to arrive
What does the spline on the end of the driveshaft look like ?----Full of rust?----If so the spline in the crank may be damaged / weak.---A potential failure point.
