88Glastron
- Nov 11, 2008
- 34
I was replacing the water pump and I noticed that my intermediate shift shaft had some resistance to it. I removed the shaft and applied some 2-4-c to it and reinstalled it with its washer and cotter pin. I then reattached the gear housing and the drive shaft housing. As I was tightening the last nut I noticed these two items in question on the ground. The inside diameter is the same as the intermediate shift shaft but I do not remember them being there. They do not appear to be a part of the water pump so I checked the exploded view of both lower units and it showed the intermediate shift shaft only having one washer and the cotter pin which are both still there. Am I missing something?
