Re: NEED HELP! just put in a new radio
i just got my hands on a multitester again and this time did it right. it ook me a while cause its been raining alot lately. so when the radio is on the red and yellow wire is getting about 13.5 volts. and when the radio shuts off its still getting the same. i noticed that it stays on for the most part when the volume is down? so i guess its not the power source? correct? what could it be?
When the radio is off then you should only be getting power to the yellow wire, the red should be run to the switched accessory point at the ignition.
Is the stereo wired into a circuit that other things are wired into as well? Is this circuit on a breaker?, and is that circuit being overloaded?
Once you have gone that far and verified you are not overloading a breaker and there are no shorts in the power circuit then proceed
I would suggest tracing the speaker wires, check them for crimps, exposed wires, shorts, etc.
Once you have done that and verified all connections and wires are free from defect, you can try isolating the speakers from the stereo by simply unplugging them one at a time and seeing if the problem persists, if when you remove a speaker from the circuit the problem goes away, then you may have a speaker that has shorted within itself which would trigger the protection circuit in the stereo.
