Need Help On Winterizing Asap!!!
AJSVFORCE
I do know the correct way to drain the block,my problem is
I just bought a 1988 Donzi Ragazza bowrider with 350 V8,and I cannot get to the block drain plugs!
Is there another method to winterize that is just as good as removing the block plugs?
I will try and post a pic to give you an idea of what I am
dealing with.
This is my first post,I am new to the forums and have already learned so much just from reading.
This is my first boat,my parents and brother had boats but they were powered by four bangers and had plenty of room to get to anything you needed to work on.
This donzi looks like a nightmare to get to anything!
Thanks for the help,
Andy
Re: Need Help On Winterizing Asap!!!
Ayuh,...
It's probably necessary to Remove a few pieces of the Boat,...
But,...
Pulling the Block Drains is about the Only, Foolproof method...
